Group: DynoMotion Message: 12103 From: dms.davidstevenson Date: 8/11/2015
Subject: "Unable to open Tool Table file" error
Hello,
Just started getting the error message "Unable to open Tool Table file:" when KMCNC is started. Typically we don't use the tool table for our application. Machine has worked for about 8 months without any sign of this previously.
Any thoughts on what might be causing this? Version number is 433k.
David.
Group: DynoMotion Message: 12105 From: Tom Kerekes Date: 8/11/2015
Subject: Re: "Unable to open Tool Table file" error
Hi David,
Which Tool Table File to be used is specified in KMotionCNC | Tool Setup | Tool Setup Files |  Tool File.
Make sure it specifies a valid Tool File.  Normally it points to <Install>\G Code Files\Default.tbl
Group: DynoMotion Message: 12106 From: David Stevenson Date: 8/11/2015
Thanks for your help. I wasn't sure which file to check.
Best regards,
David.
On 8/11/2015 8:02 PM, Tom Kerekes tk@... [DynoMotion] wrote:
Hi David,
